Welcome to ZenTalk Community!
435468members
379961posts
Community Activity
Higher battery drain on V35.1210.1420.78 Android 15.
So after using the Android 15 update for 2 weeks the battery life is still terrible forcing me to use ultra durable mode to reach the end of the day with 20% left. Normal i was using Dynamic mode and ended the day with 40% left. ( yes my device was r...
Koudmaker by Rising Star II
  • 19 Views
  • 1 replies
  • 1 kudos
ASUS SimPro Dock2 網路孔使用問題
您好,請問有人碰到相同問題嗎使用simpro dock 2 的網路孔時會跟公司的IP沖到導致無法使用網路,但是使用筆電本身的網路孔就正常;2者都使用相同固定IP,使用時都會停用另一個網路,已經換過一個simpro dock 2還是一樣
Puedo abrir ASUS TUF A15 sin perder garantia?
Hola, hace una semana compre mi ASUS TUF A15 FA507NU y quisiera agregarle más RAM y otro NVME M.2 para más almacenamiento, pero tengo 2 dudas:- Al abrirla pierdo la garantía?- En caso de que no, si le añado estos extras de RAM Y SSD pierdo garantía?G...
downgrading of performance over time
I have a Asus Vivobook K5504VA. It came with a 120hz screen that worked fine when I was under warranty. I noticed recently that I can only get 60hz and the option for 120hz is not there anymore. I called Asus and had multiple support calls/emails wit...
Getting started
We want your journey here to be as great as can be, so we have put together some links to help you get quickly familiarized with the ASUS ZenTalk Community.
Announcements
Top Kudoed Authors
