Welcome to ZenTalk Community!
435906members
380593posts
Community Activity
ASUS Armoury Crate no funciona
Hace unos días se me actualizo el Armoury Crate lo que cambio la visualización de la aplicación, pero desde entonces no me detecta el estado de mi pc (ASUS TUF GAMING F15), como ser la GPU, la RAM, las temperaturas, ya intente con la herramienta de d...
GoNz4L0 by Visitor
  • 2 Views
  • 0 replies
  • 0 kudos
Fps drop in rog8 android 15
I updated to Android 15, and my gaming experience has significantly worsened with noticeable lag and frame drops. Before the update, I could play Zenless Zone Zero at 61 FPS, but after the update, it dropped to 45 FPS. This has made me quite worried....
Film1 by Star I
  • 20 Views
  • 1 replies
  • 1 kudos
Tengo una falla en mi Asus rog strix g16
Hola, desde el día que compre mi portátil y lo encendí me presenta una falla que al usarlo con cargador se suspende y no se puede usar, ya actualice drivers cambie Windows actualicé los drivers de la gráfica le cambié el cargador y aún así falla, se ...
主螢幕我的最愛匣可以設定成5個嗎?
主螢幕若設定成4x5或4x6時,底下我的最愛匣只有4個,一定要主螢幕設定成5x5或5x6才能把我的最愛匣變成5個?為什麼不能4x6的主螢幕搭配5個我的最愛匣呢?以前Zenfone 5Q就可以,麻煩改進,謝謝。#rog phone 9 pro edition
Does the ZenFone 10 have Dolby Atmos?
I have had Motorolas all my life and have decided I want something (for a lack of a better term) good. but although I've heard stuff about the DAC will it still have Dolby Atmos like Moto g???
zenfone10更新後自動出現「工作應用程式」分類標籤,無法移除。
今日使用zenfone10(個人使用,非公司配發手機)收到通知更新android15系統,更新後桌面自動出現「個人」、「工作」分類標籤,少部分應用程式被分類到「工作」標籤畫面。檢索後得知是「工作資料夾」功能https://support.google.com/work/android/answer/6191949?sjid=2183853659993275782-NC&hl=zh-Hant,但依照該說明操作,於「設定」-›「密碼與帳號」頁面,卻找不到「工作」分頁標籤。請問,想要移除該分類功能,恢...
KT25 by Visitor
  • 19 Views
  • 1 replies
  • 0 kudos
AeroActive Cooler X problem
When I use AeroActive Cooler X, I plug in charger to the AAC X port and switch to frozen mode it disconnected and connect the power 1 to 2 times. Sometimes worst, straight not charging nor taking power at all, but after I unplug AAC from phone and pl...
Getting started
We want your journey here to be as great as can be, so we have put together some links to help you get quickly familiarized with the ASUS ZenTalk Community.
Announcements
Top Kudoed Authors
