All-New Edge AI Systems Shaping the Future
14th Gen Intel® Core™ i9
Support Dual 450W GPUs
Rugged & Durability Design
Revolutionize computing power with edge AI systems
The Game-Changing Platform for AI Application
Powerful and scalable GPU computing
Latest computing platforms
Exclusive thermal design
Robust Power Design
Anti-vibration Design
Industrial Feature Set & Rich I/O
Certification Compliance
Software Support for Easy Integration
Leading dual-GPU and accelerated AI computing power
Versatile computer vision applications
Rich peripheral expandability for machine vision
Ready to scale up for autonomous vehicles
Engineered for intelligent video analytics
Full Spectrum of Edge AI Systems
Product for your solution
Rugged edge AI GPU computer supporting up to dual 450W GPU card and 14th/13th/12th Gen Intel® Core™ processor
Rugged edge AI GPU computer supporting up to 450W GPU card and 14th/13th/12th Gen Intel® Core™ processor
14th/13th/12th Gen Intel® Core™ rugged edge GPU computer supports up to 200 W GPU and versatile expansion capabilities
Rugged High Performance Edge Computer Supports Intel® 14th/13th/12th Core™ CPU with Intel® R680E Chipset, 2.5” Hot-Swappable HDD Tray, RAID 0/1 and up to 200W Graphics Card.
Rugged High Performance Edge Computer Supports Intel® 14th/13th/12th Core™ CPU with Intel® R680E Chipset, 2.5” Hot-Swappable HDD Tray, RAID 0/1 and Rich I/O.
Rugged fanless edge AI computer supporting NVIDIA® or Intel® MXM GPU and 12th Gen Intel® Core™ processor
Intel 10th Gen. Core-I and Xeon processors Intelligent Edge server with versatile connectivity, 3 expandable PCIe slots, supporting AI inferencing
Arm System, NVIDIA Jetson, LPDDR5, USB3, GbE, 10G LAN, 4 POE LAN, HDMI, M.2 E, M.2 M, M.2 B, 9-36V
Arm System, NVIDIA Jetson, LPDDR5, USB3, Dual LAN, HDMI, M.2 E, M.2 M, M.2 B, AEM, Dual SIM, 12-24V
Arm System, NVIDIA Jetson™ Orin™, LPDDR4, eMMC, USB3, Dual LAN, HDMI, M.2 E, M.2 B, M.2 M, AEM, Dual SIM, 12-24V
Arm System, NVIDIA Jetson, LPDDR4, eMMC, USB3, Dual LAN, HDMI, M.2 E, M.2 M, mini PCIe, AEM, Dual SIM, 12-24V
Resources
ASUS IoT’s New Edge AI Computers with 14th Gen Intel
ASUS IoT Unveils NVIDIA Jetson Portfolio at COMPUTEX 2024
ASUS IoT Boosts Smart Agriculture with AMR
Smart Border Management with ASUS IoT PE4000G
ALPR Applications Take Advantage of ASUS IoT PE1000N
Innovating for progress: ASUS IoT and PE1000N drive smart city
FAQ
Q1. Where are the business opportunities for embedded graphics?
In the modern world, the AI revolution brings opportunities in applications such as industrial automation, autonomous vehicles, video analytics, and more. All these operations rely heavily on graphics computing and matrix multiplication. GPU (Graphics Processing Unit) computing precisely fulfills these requirements, particularly when it comes to parallel processing and computationally intensive workloads. It serves as an AI engine in the field, where real-time operations take place. When computers are built ruggedized, it unlocks the possibility to process data locally, reducing latency and conserving bandwidth, making mission-critical calculations reliable and efficient. Thus, GPU computability and ruggedness are the two indispensable elements in edge AI. -
Q2. What makes ASUS IoT stand out from other brands?
Over the years, ASUS has earned a prestigious reputation for motherboard and graphics card design. Across a growing spectrum of products, ASUS continuously challenges itself to adapt and evolve. Having served various product categories on a global scale for three decades, ASUS has cultivated robust customer service capabilities and a strong supply chain management system. With this proven foundation of competency, ASUS IoT, a dedicated Business Unit focusing on industrial applications, builds industrial PC offerings with pride and confidence. -
Q3. What is the benefit of purchasing a GPU with an edge AI computer?
To start with, it spares you the effort of logistics, installation, and testing. Secondly, it addresses quality concerns such as compatibility and mechanical strength. When the deployment environment involves different levels of shock and vibration, the mechanical design of the GPU retainer becomes critical. Lastly, after a batch of equipment has been running for years, certain problems may arise. It's always better to reach out to a single vendor to sort it out, instead of contacting multiple vendors for different key components. The efforts can be substantial once you take a few more things into account. Unity of the whole system can be a solution for optimal TCO (Total Cost of Ownership). -
Q4. What is the length of the warranty coverage and lifecycles of edge AI computers?
Typical warranty covers 2-3 years, depending on regional warranty policies. Extensions can be offered upon request. Edge AI computers offer a standard lifecycle of 7 years. Extensions on the lifecycle are also possible upon request. For embedded graphics cards, the lifecycles are listed below:
Note: May adjust based on module vendor’s roadmap
Q5. How to choose the ideal edge AI computer for certain vertical applications?
From a computing workload capacity point of view, the PE4000G, PE6000G, and PE8000G may catch your eye. With the latest Intel 12th Gen desktop platform, GPUs ranging from a single 200W TDP GPU to dual 450W TDP GPUs, and dual DDR5 SO-DIMM, this series offers the strongest combination of computational elements. When focusing on specific inference usages, the NVIDIA Jetson-based PE1000N series is undoubtedly the top candidate. It offers multiple SoM options, ranging from Nano, TX2 NX, Xavier NX, Orin Nano, Orin NX, and more. With efficient power consumption and a compact footprint, the PE1000N series is not only scalable in computing capability but also ideal for large-scale deployment, even in outdoor environments. Finally, the PE3000G amazes you with its extraordinary durability. This GPU computer boasts 100% fanless operation, an embedded Intel MXM GPU, and a patented passive thermal solution. It is noise-free, has a prolonged MTBF (Mean Time Between Failures), features an embedded GPU, and offers anti-shock-and-vibration capabilities that exceed military standards. These remarkable features make it stand out.
Get Engaged with us
Contact us -
Learn More About ASUS IoT
Visit Website -
Buy Now
Find a Partner
