ROG-THOR-1200P
  • Features
  • Tech Specs
  • Gallery
  • Support
ROG-THOR-1200P
ROG Thor 1200W Platinum Power Supply Unit stands out with Aura Sync and an OLED display
  • Aura Sync : Advanced customization with addressable RGB LEDs and Aura Sync compatibility
  • OLED Power Display : Real-time power draw monitoring with OLED Power Display
  • ROG Thermal Solution : 0dB cooling with dustproof IP5X Wing-blade Fan and ROG heatsink design
  • 80 PLUS Platinum : Built with low-ESR capacitors and other premium components
  • Sleeved Cables : For easy building and superior aesthetics
HARNESS THUNDER
Inside and out, our first PSU is packed with innovative ideas. Externally, Aura Sync RGB illumination and an integrated OLED information panel enable unique customization and monitoring options for your ROG gaming rig. Under the hood, high-quality capacitors, a 135mm Wing-blade fan, and large heatsinks allow the ROG Thor 1200W to achieve LAMBDA A+ and 80 PLUS® Platinum certifications, making it ideal for PC enthusiasts who demand performance perfection.
ETA A logo LAMBDA A+ logo AURA SYNC logo 80 PLUS PLATINUM logo
ROG Thor 1200W Platinum top view
Aura Sync
Outshine the competition AURA SYNC logo
ASUS Aura Sync is an illumination ecosystem that lets you synchronize lighting effects across your gaming rig, components, and peripherals. The ROG Thor lets you take full control with internal Aura RGB LEDs that connect to the 4-1 addressable RGB header on select motherboards.
- Two included connector cables allow you to connect the ROG Thor to the addressable RGB header featured on select ASUS Motherboards or to create a daisy chain of ROG Addressable LED Strips.
- If the the connector cables are not used, the ROG Thor's default effect and color is static red.
Aura Sync lighting effects
ROG Thor 1200W Platinum side view featuring display for real-time power draw
OLED POWER DISPLAY
The ROG Thor 1200W Platinum is the first PC PSU in the world to feature an integrated OLED panel, offering a real-time display of power draw. Now you can see at a glance how much juice your rig is using.
0 dB feature activated when temperature reads below 50 °C
WING-BLADE FAN
We’ve equipped the ROG Thor 1200W Platinum with a 135mm patented Wing-blade fan to maximize component lifespan. IP5X dust-resistance keeps it spinning freely and 0dB technology utilizes thermal sensors to allow the fan to switch off completely at lower wattages — enabling totally silent operation.
ROG heatsinks for ROG Thor 1200W Platinum
ROG HEATSINK
The integrated ROG heatsinks have 2x more volume than traditional designs, resulting in 20% lower temperatures inside the ROG Thor 1200W Platinum. This extends the lifespan of components and allows 0dB operation for a longer duration than standard designs. The heatsinks are so effective that fan noise never exceeds 20dB, allowing ROG Thor to achieve LAMBDA A+ certification.
ROG Thor 1200W Platinum internal structure with 80 PLUS Platinum certification
80 PLUS PLATINUM CERTIFICATION
The ROG Thor 1200W Platinum utilizes top-end Japanese capacitors to ensure efficient operation. This has earned an 80 PLUS Platinum certification, which guarantees 89% efficiency at 100% load and 92% at 50% load. The increased efficiency produces less heat, reducing fan noise and increasing reliability.
Close-up of the ROG Thor 1200W Platinum sleeved cable
SLEEVED CABLES
We know you'll want to get building right away, so we've included high-quality sleeved and standard cables. The sleeved cables include one 24-pin, four 6+2-pin PCI-e cables and two 8-pin CPU cables. We've also included an RGB connector that plugs into the addressable RGB header on your ASUS motherboard.
For something punchier than pure black, we’ve teamed up with CableMod to offer a 20% discount. Customize cable colors, length, and materials to match your rig. Click here for more info
The ROG Thor comes with two types of PCI-E power cables in the box: an individually sleeved set for showcase systems, and, to fuel heavily overclocked graphics cards, cables with embedded capacitors that reduce voltage ripple.
10-YEAR WARRANTY
We'dre so confident about the reliability of the ROG Thor 1200W Platinum that we back it with a 10-year* warranty.
*Core product operation is guaranteed for 10 years. The OLED panel and RGB LEDs are subject to a 3-year warranty.
10-YEAR LIMITED WARRANTY logo
Power Supply Calculator user interface
How many watts do you need? Click here to find out which PSU fits your build.
CUSTOMER REVIEWS
Recommended Products
ROG-THOR-850P
ROG Thor 850W Platinum Power Supply Unit stands out with Aura Sync and an OLED display
ROG-STRIX-750G
The ROG Strix 750W Gold PSU brings premium cooling performance to the mainstream.
ROG-STRIX-850G
The ROG Strix 850W Gold PSU brings premium cooling performance to the mainstream.
ROG-STRIX-1000G
The ROG Strix 1000W Gold PSU brings premium cooling performance to heavyweight gaming rigs
ROG Thor 1000W Platinum II EVA Edition
ROG Thor 1000W Platinum II EVA Edition is the quietest PSU in its class.
ROG LOKI SFX-L 750W Platinum
ROG Loki 750W Platinum is a high-wattage PSU for boundary-breaking SFF builds.
ROG LOKI SFX-L 850W Platinum
ROG Loki 850W Platinum is a high-wattage PSU for boundary-breaking SFF builds.
ROG LOKI SFX-L 850W Platinum White Edition
ROG Loki 850W Platinum White Edition is a high-wattage PSU for boundary-breaking SFF builds.
Related Products
ROG STRIX XF 120
Whisper-quiet, 4-pin PWM fan for PC cases, radiators or CPU cooling
2021 ROG XG Mobile
  • Up to NVIDIA®GeForce RTX™ 3080 Laptop GPU
  • HDMI 2.0b
  • DP 1.4 support G-SYNC
  • RJ-45 LAN port
  • Power Connector
  • USB 3.2 Gen 1 Type-A
  • SD Card reader(Standard)/UHS-II(312MB/s)
ROG Eye S
Full HD 60 fps webcam with AI-powered, noise-canceling mics for superior live-streaming audio and a compact and foldable design that’s easy to carry and attach instantly to any laptop
ROG Herculx Graphics Card Holder
The robust ROG Herculx Graphics Card Holder securely fortifies even the most powerful cards, plus offers an easy-to-use design and extensive compatibility.
ROG Strix SQ7 Gen4 SSD 1TB
1 TB M.2 PCIe® Gen 4 NVMe® , internal solid state drive with DRAM buffering and large SLC cache, up to 7000 MB/s maximum file transfer speed, compatible with PC and PlayStation® ™5, TCG Opal and AES 256-bit encryption, plus NTI Backup Now EZ software
ROG XG Mobile (2023)
  • Up to NVIDIA®GeForce RTX™ 4090 Laptop GPU
  • HDMI2.1 FRL
  • RJ-45 LAN port
  • Power Connector
  • USB 3.2 Gen2 Type-A
  • USB 3.2 Gen2 Type-C
ROG Raikiri
The ROG Raikiri PC controller features two rear buttons, left and right triggers with short and full range of motion plus dead zone customization, built-in ESS DAC for supreme audio, joystick sensitivity and response curve customization. The ROG Raikiri is ideal for gaming on PC, laptop or the next gen Xbox console.
ROG Raikiri Pro
The ROG Raikiri Pro PC Controller features an OLED display, four rear buttons, selectable triggers, ESS DAC, customizable joystick sensitivity and response curves, and tri-mode connectivity. It’s ideal to play in wired USB-C, 2.4GHz, or Bluetooth on PCs
