- Features
- Tech Specs
- Awards
- Gallery
- Support
ROG-STRIX-850G-WHITE
The ROG Strix 850W White Edition PSU, with 80 PLUS Gold certification, brings premium performance to the mainstream.
- ROG heatsinks cover critical components, delivering lower temperatures and reduced noise.
- Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure.
- Dual ball fan bearings can last up to twice as long as sleeve bearing designs.
- 0dB Technology lets you enjoy light gaming in relative silence.
- An 80 Plus Gold Certification is the result of Japanese capacitors and other premium components.
- White Edition Design include a white case, modular cables, stickers, and magnets.
- Fully modular cables keep your rig neat and tidy.
- 10-year warranty included.
Video Reviews
How to WISELY PICK your PC GAMER power supply in 2023!
I BUILD the ULTIMATE AMD PC at 3500€ !
Build PC GAMER ROG Full White Powered by ASUS à 5000 €
Dominate WARZONE, THE Gaming PC Configuration to WIN. 🎁🎁🎁
【自作PC】美しすぎるケースとオールホワイトのパーツで白いPCを組む【ASUS|i5 13600K|RTX3060】
【自作PC】デザイン最高な真っ白のゲーミングPCを作りたい
The white theme solution by ASUS component.
Assemble a computer for 160,000THB, the best with ASUS GEFORCE RTX 3080
new computer set white Strong specs can play every game.
The block is excellent, I have no complaints about it. There is enough power even for a pair of top-end views.
Pristine Chilled Power
The ROG Strix 850W White Edition PSU features sleeved modular cables, a variety of decals, and is dressed to compliment the aesthetics of a white gaming rig. Massive ROG heatsinks trickle down from the mighty ROG Thor series and Axial-tech fan design from our premium NVIDIA RTX™ graphics cards also make an appearance. Below the surface, low RDS (on) MOSFETs and premium Japanese capacitors take on power delivery with ease. The result is an incredibly quiet and efficient power supply with the reserves to handle the most intense gaming scenarios.
Cooling
ROG Heatsinks
Let it sink in
The integrated ROG heatsinks have 2x more volume than traditional designs, resulting in significantly lower temperatures inside Strix PSUs. This extends the lifespan of components and allows 0dB operation for a longer duration than standard designs. The heatsinks are so effective that fan noise stays whisper quiet, even under full load.
Axial-tech Fan Design
Better, faster, stronger
Originally developed for top-end ROG graphics cards, Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure. For ROG Strix series power supplies, we've scaled that design to 135mm so it keeps things cool at low RPMs while producing less noise.
Dual Ball Fan Bearings
2x longer lifespan
Dual ball bearings boast a remarkable lifespan of 80,000 hours, lasting twice as long as sleeve bearings and exceeding even fluid dynamic bearings. Ensuring long-lasting, reliable cooling with minimal noise for ROG STRIX Gold series.
Engineering
Heart of gold
Top-end Japanese capacitors ensure efficient operation and have helped the Strix earn an 80 PLUS Gold certification. The increased efficiency also results in less heat, reducing noise and increasing reliability.
Software
GPU Tweak II
Monitor, tweak, and tune
The ASUS GPU Tweak II utility takes graphics card tuning to the next level. It allows you to tweak critical parameters including GPU core clocks, memory frequency, and voltage settings, with the option to monitor everything in real-time through a customizable on-screen display. Advanced fan control is also included along with many more features to help you get the most out of your graphics card.
XSplit
Premium streaming
XSplit offers a premium streaming experience with in-game annotations and other advanced features. Enjoy a free license with the purchase of select ASUS graphics cards. See you online!
Learn more about XSplit >
wtfast
Play lag-free
We've partnered with wtfast to help you to play free from lag, latency issues, and lost packets. With a 6-month subscription to the wtfast Gamers Private Network, you'll enjoy lower ping for a smoother, more fluid online gaming experience. Buy an ASUS graphics card - and don't be left waiting!
Learn more about wtfast >
Quantumcloud
Profit from GPU power
Quantumcloud is a simple and secure service that lets you effortlessly earn extra money by putting your idle GPU to work. Through an easy-to-use app, your computer can help run cloud-based applications, making you money in the process. Earnings are automatically transferred to your WeChat or PayPal account, and your privacy remains intact because Quantumcloud doesn't collect your personal data. Get started making money today!
Learn more about Quantumcloud >
Experience
Tabula rasa
White components can easily achieve a clean aesthetic or adopt ambient RGB colors for greater customization than their darker or painted counterparts. With a white case, modular cables, stickers, and magnets, this white edition PSU is a perfect fit for any white gaming rig.
Fully Modular Cables
Plug in
Keep your rig neat and tidy with fully modular cables. And if you'd like to add a dash of color to your build, the included CableMod coupon will set you on your way towards next-level customization.
More info >
10-year Warranty
A decade of power
We're so confident about the reliability of the ROG Strix Series PSUs that we back them with a 10-year worldwide warranty.
0%
CUSTOMER REVIEWS
Recommended Products
ROG-STRIX-1000G
The ROG Strix 1000W Gold PSU brings premium cooling performance to heavyweight gaming rigs
ROG-STRIX-850G-GUNDAM-EDITION
The ROG Strix 850W GUNDAM EDITION PSU, with a GUNDAM theme and 80 PLUS Gold certification, brings premium performance to the mainstream.
ROG THOR 850W Platinum II
ROG Thor 850W Platinum II is the quietest PSU in its class.
ROG Strix 850W Gold Aura Edition is a cool, quiet and powerful PSU, engineered for efficiency in striking style.
The ROG Strix 1000W Gold PSU brings premium cooling performance to the mainstream
Related Products
ROG STRIX B560-E GAMING WIFI
Intel® B560 LGA 1200 ATX motherboard with PCIe® 4.0, 14+2 teamed power stages, Two-Way AI Noise Cancelation, WiFi 6E (802.11ax), Intel 2.5 Gb Ethernet, three M.2 slots with heatsinks and NVMe SSD support, USB 3.2 Gen 2x2 USB Type-C®, SATA and Aura Sync RGB lighting
ROG STRIX Z590-A GAMING WIFI II
Intel®Z590 LGA 1200 ATX motherboard with PCIe 4.0, 14+2 teamed power stages, Two-Way AI Noise Cancelation, AI Overclocking, AI Cooling, AI Networking, WiFi 6 (802.11ax), Intel® 2.5 Gb Ethernet, three M.2 slots with heatsinks, USB 3.2 Gen 2x2 USB Type-C®, SATA and Aura Sync RGB lighting
ROG STRIX X570-E GAMING WIFI II
AMD X570 ATX gaming motherboard with PCIe® 4.0, 12+4 power stages, and WiFi 6E (802.11ax), Realtek 2.5 Gb Ethernet, Two-Way AI Noise Cancelation, dual M.2 with heatsinks, SATA 6 GB/s, USB 3.2 Gen 2 Type C and Aura Sync RGB lighting
AMD B550 Ryzen AM4 Gaming ATX motherboard with PCIe® 4.0, 12+2 teamed power stages, Intel® 2.5 Gb Ethernet, WiFi 6E, Two-Way AI Noise Cancelation, dual M.2 slots with heatsinks, SATA 6 Gbps, USB 3.2 Gen 2 and Aura Sync RGB lighting
ROG STRIX Z690-F GAMING WIFI
Intel®Z690 LGA 1700 ATX motherboard with PCIe®5.0, 16+1 power stages, DDR5 memory support, Two-Way AI Noise Cancelation, AI Overclocking, AI Cooling, AI Networking, WiFi 6E (802.11ax), Intel®2.5 Gb Ethernet, four M.2 slots with heatsinks, PCIe 4.0 NVMe®SSD support, M.2 backplate, PCIe®Slot Q-Release, USB 3.2 Gen 2x2 Type-C®, SATA and Aura Sync RGB lighting
ROG STRIX Z690-A GAMING WIFI D4
Intel®Z690 LGA 1700 ATX motherboard with PCIe®5.0, 16+1 DrMos, Two-Way AI Noise Cancelation, AI Overclocking, AI Cooling, AI Networking, WiFi 6 (802.11ax), Intel®2.5 Gb Ethernet, four M.2 slots with heatsinks PCIe 4.0 NVMe®SSD support, M.2 backplate, PCIe®Slot Q-Release, USB 3.2 Gen 2x2 Type-C®, SATA and AURA Sync RGB lighting
ROG STRIX Z690-G GAMING WIFI
Intel® Z690 LGA 1700 mATX motherboard with PCIe® 5.0, 14+1 DrMos, DDR5 memory support, Two-Way AI Noise Cancelation, AI Overclocking, AI Cooling, AI Networking, WiFi 6E (802.11ax), Intel® 2.5 Gb Ethernet, three M.2 slots with heatsinks, PCIe® 4.0 NVMe® SSD support, M.2 backplates, USB 3.2 Gen 2x2 Type-C®, SATA and AURA Sync RGB lighting
ROG STRIX Z690-I GAMING WIFI
Intel® Z690 LGA 1700 ITX motherboard with PCIe® 5.0, 10+1 power stages, Two-Way AI Noise Cancelation, AI Overclocking, AI Cooling, AI Networking, WiFi 6E (802.11ax), Intel® 2.5 Gb Ethernet, two M.2 slots with heatsinks and backplates, two Thunderbolt™ 4 USB Type-C®, SATA and Aura Sync RGB lighting
