ASUS ZenWiFi
WiFi Coverage Everywhere. Always Secure.
Whole-home Coverage
The ZenWiFi XD6 series system consists of a pair of ASUS AX5400 WiFi 6 routers, featuring unique technologies that give you superfast, reliable and secure WiFi connections — inside or outside your home!
Smart & Flexible Backhaul Configuration
ASUS ZenWiFi XD6 series give you alternative backhaul options: Ethernet and WiFi. The router intelligently chooses the most reliable method for you based on connection quality. If you prefer, you can also manually choose the type of backhaul connection.
True 8K Streaming
ZenWiFi XD6 series put your WiFi into top gear! With a total bandwidth of up to 5400 Mbps, it's up to 2.2X faster* than WiFi 5 routers**.
*The 160MHz bandwidth may be unavailable in the 5GHz band in some regions / countries due to regulatory restrictions.
* Compatible WiFi 6 device required.
** The data compares speed of 4x4 11ax on 5GHz 160MHz bandwidth with 1024QAM modulation to speed of 4x4 11ac on 5GHz 80MHz with 256QAM modulation.
*** The number of speed is calculated with data rate of 2.4 GHz band and of 5 GHz band, which are respectively 574 and 4804 Mbps. And the DFS channels may not be supported in some countries due to local regulations.
The smoothest WiFi for all your devices
WiFi 6 (802.11ax) is engineered to cope with multiple devices, so even if your home's packed with WiFi devices, you'll still enjoy fast WiFi everywhere. WiFi 6 also uses special Target Wake Time technology that reduces the power consumption of connected devices by up to 7X, extending their battery life*.
Works with any WiFi device
WiFi 6 is fully compatible with all generations of WiFi, so you can connect any device to ZenWiFi XD6, no matter if it uses 802.11ac, 802.11n or other previous WiFi standards.
Flexible Network Naming
Uniquely, ZenWiFi lets you choose how you name your WiFi networks: a single name for everything, or separate names for each frequency band. The choice is yours!
Easier-than-ever Setup
3-step setup with the ASUS Router app
1
Turn on ZenWiFi XD6 series products
2
Create a WiFi network name and an admin account
3
Wait for several minutes, and you're done!
What makes ZenWiFi XD6 series setup so easy?
- One-time setup, with auto synchronization for all the hubs in each package
- Hassle-free: each unit can work as the main router or an extender node
Safer Place for Everyone
AiProtection Pro with Advanced Parental Controls is free for life. It gives you total peace of mind, and you can keep an eye on everything that's happening on your network via the mobile app.
Some routers only offer 3 years of protection, ASUS AiProtection has you covered for the life of your product.
Intrusion Prevention System (IPS) blocks all common internet-based attacks.
AiProtection uses Trend Micro's official database to identify and block known malicious sites, preventing infection even before you click.
Even if an already-infected device is connected to ZenWiFi, AiProtection prevents any personal data on the device from being compromised.
More Stable WiFi with Wired Connections between ZenWiFi Hubs
If you have Ethernet ports in your walls, you can set ZenWiFi AX Mini to use Ethernet backhaul, reserving all WiFi bands for your wireless devices for even more stable and reliable networking.
AiProtection has everything you need in one place: it's super-easy to view or change security settings on each of your family member's devices, so your kids can be safer when surfing!
More Privacy, Anywhere
Instant Guard gives you one-click secure internet access via ZenWiFi XD6 series from anywhere in the world, thanks to its encrypted data-tunneling VPN technology. With ZenWiFi XD6 , you can take your home network with you wherever you go — and say goodbye to web-based third-party VPNs!
Smart Looks for Smart Homes
ZenWiFi XD6 series work perfectly with smart-home services- including Alexa skills.
Read more
Space-saving wall-mount
The iconic design comes with a wall-mount kit. Hang it on the wall or place it anywhere, the choice is yours!
*Wall mount kit may not be available in all regions/ countries. Please check with your retailer for exact offers.
AiMesh Technology
Easy setup. Flexible management.
Even non-experts can quickly set up AiMesh technology, while more experienced users will appreciate the comprehensive advanced networking features.
How do I expand my network?
Flexible and Scalable Wireless Networking
If you need more coverage or new functions, you can simply add another compatible router to your AiMesh network at any time!
Learn more about AiMesh
- The terms HDMI and HDMI High-Definition Multimedia Interface, HDMI trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc. in the United States and other countries.
- Actual data throughput and WiFi coverage will vary from network conditions and environmental factors, including the volume of network traffic, building material and construction, and network overhead, result in lower actual data throughput and wireless coverage.
- Quoted network speeds and bandwidth based on current IEEE 802.11ac specifications. Actual performance may be affected by network and service provider factors, interface type, and other conditions. Connected devices must be 802.11ac-compatible for best results.
- WPA/WPA2 enterprise is only available on single router, is not available under AiMesh mode.
- When traditional QoS is enabled, there will be limitations due to the actual Internet service bandwidth and different environment, and there may be a risk of speed reduction.
- Due to the different power supply requirements on USB external hard disk and 4G/5G Modem device, to ensure that the external device can be used stably, if the USB external device exceeds the standard USB 2.0 (5V/500mA) and USB 3.1 Gen 1 (5V/900mA) power supply requirements, you need to use it with an independent external power supply.
- If you use the product in conjunction with a third party service, you are responsible for complying with the third party provider's terms and conditions and privacy policy and are also at the risk of such use. ASUS does not provide support or guarantee continuous integration support for products that are not part of ASUS.
- The device is restricted to indoor use only when operating in the 5150-5350 MHz frequency band in certain regions, including the EU, Asia-Pacific countries, Australia, and Canada. Outdoor use in this band may be prohibited or require regulatory approval. Check local regulations before deployment.
- For models with Time machine support, starting with macOS 26 (Tahoe), Time Machine no longer supports creating new backups on USB-connected storage devices. Existing Time Machine drives that were previously configured remain compatible and can continue to be used for backup and restoration.
