ASUS ZenWiFi AX Mini (XD4)
ASUS ZenWiFi AX Mini (XD4) mesh system, front view, tilted 45 degrees
Awards
Video reviews
Media reviews
ASUS ZenWiFi AX Mini (XD4) white edition
ASUS ZenWiFi AX Mini (XD4) black edition
ASUS ZenWiFi
WiFi Coverage Everywhere. Always Secure.
Whole-home Coverage
ASUS ZenWiFi AX Mini (XD4) provides whole-home mesh WiFi coverage
The ZenWiFi AX Mini system consists of one ASUS AX1800 WiFi 6 router and two extending node, featuring unique technologies that give you superfast, reliable and secure WiFi connections — inside or outside your home!
ASUS ZenWiFi AX Mini (XD4) 3pk icon
4800 sq.ft.
5+ rooms
ASUS ZenWiFi AX Mini (XD4) 2pk icon
3300 sq.ft.
4+ rooms
ASUS ZenWiFi AX Mini (XD4) 1pk icon
2200 sq.ft.
2+ rooms
4800 sq.ft.
5+ rooms
3300 sq.ft.
4+ rooms
2200 sq.ft.
2+ rooms
Soccer match on screen
WiFi 6
True 8K Streaming
WiFi6 ,8k streaming and live stream icons
ZenWiFi AX Mini puts your WiFi into top gear! With a total bandwidth of up to of 1800 Mbps, it's up to 1.4X faster* than WiFi 5 routers **.
* Compatible WiFi 6 device required.
** The data compares speed of 2X2 11ax on 5GHz 80 MHz bandwidth with 1024QAM modulation to speed of 2x2 11ac on 5GHz 80MHz with 256QAM modulation.
The smoothest WiFi for all your devices
WiFi 6 (802.11ax) is engineered to cope with multiple devices, so even if your home's packed with WiFi devices, you'll still enjoy fast WiFi everywhere. WiFi 6 also uses special Target Wake Time technology that reduces the power consumption of connected devices by up to 7X, extending their battery life*.
Works with any WiFi device
WiFi 6 is fully compatible with all generations of WiFi, so you can connect any device to ZenWiFi AX Mini, no matter if it uses 802.11ac, 802.11n or other previous WiFi standards.
ASUS ZenWiFi AX Mini (XD4) flexible network naming scenario photo
Flexible Network Naming
Uniquely, ZenWiFi lets you choose how you name your WiFi networks: a single name for everything, or separate names for each frequency band. The choice is yours!
Tri-band network interface
More Stable WiFi with Wired Connections between ZenWiFi Hubs
If you have Ethernet ports in your walls, you can set ZenWiFi AX Mini to use Ethernet backhaul, reserving all WiFi bands for your wireless devices for even more stable and reliable networking.
Easier-than-ever Setup
3-step setup with the ASUS Router app
System setup interface
1
Turn on ZenWiFi AX Mini
2
Create a WiFi network name and an admin account
3
Wait for 3 minutes, and you're done!
What makes ZenWiFi AX Mini setup so easy?
  • One-time setup, with auto synchronization for all the hubs in each package
  • At a glance: You must start setup using the router, which is the unit with a removable clear plastic strip wrapped around it.
ASUS ZenWiFi AX Mini (XD4) product photo
Make the Internet a
Safer Place for Everyone
AiProtection Classic with Parental Controls is free for life. It gives you total peace of mind, and you can keep an eye on everything that's happening on your network via the mobile app.
AiProtection icon
Commercial Grade Security
Parental controls icon
Parental Controls
ASUS ZenWiFi AX Mini (XD4) provides advanced parental controls
ASUS ZenWiFi AX Mini (XD4) provides commercial grade security
No Subscription Fee
Some routers only offer 3 years of protection, ASUS AiProtection has you covered for the life of your product.
24/7 Auto Update
ZenWiFi keeps your network running securely with automatic firmware updates and is always in sync with Trend Micro's cloud database, so you can always enjoy the best Internet experience.
Block Access to Malicious Websites
AiProtection uses Trend Micro's official database to identify and block known malicious sites, preventing infection even before you click.
Infection Detection and Blocking
Even if an already-infected device is connected to ZenWiFi, AiProtection prevents any personal data on the device from being compromised.
Parental Controls
URL filter and scheduling allow you to protect your family from unhealthy Internet usage behavior.
Smart Looks for Smart Homes
ZenWiFi AX Mini works perfectly with smart-home services — including Alexa skills and IFTTT — and is available in charcoal or white to suit your décor.
Read more
ASUS ZenWiFi AX Mini (XD4) scenario photos
AiMesh Technology
Easy setup. Flexible management.
Even non-experts can quickly set up AiMesh technology, while more experienced users will appreciate the comprehensive advanced networking features.
Flexible and Scalable Wireless Networking
You can set your ZenWiFi AX Mini as a standalone router, AiMesh router, AiMesh node, repeater or pair it with other ZenWiFi routers.
Learn more about AiMesh
Recommend for you
ASUS ZenWiFi AX (XT8)
0.0 out of 5 stars.
  • WiFi 6
  • AX6600, 2.4GHz 2X2+ 5GHz-1 2X2+5GHz-2 4X4
  • Very large home,multi-floor home
  • Coverage up to 5,500 Sq. ft.
  • ASUS features:AiMesh, AiProtection
AiMesh AX6100 WiFi System (RT-AX92U 2 Pack)
0.0 out of 5 stars.
  • WiFi 6
  • AX6100, 2.4GHz 2X2+ 5GHz-1 2X2+5GHz-2 4X4
PCE-AX58BT
PCE-AX58BT
PCE-AX58BT
0.0 out of 5 stars.
AX3000 Dual Band PCI-E WiFi 6 (802.11ax) Adapter with 2 external antennas. Supporting 160MHz, Bluetooth 5.0, WPA3 network security, OFDMA and MU-MIMO
PCE-AX3000
PCE-AX3000
PCE-AX3000
0.0 out of 5 stars.
AX3000 Dual Band PCI-E WiFi 6 (802.11ax). Supporting 160MHz, Bluetooth 5.0, WPA3 network security, OFDMA and MU-MIMO
RT-AX82U
RT-AX82U
RT-AX82U
extendable router icon
0.0 out of 5 stars.
  • WiFi 6
  • AX5400, 2.4GHz AX: 2x2 + 5GHz AX: 4x4
  • Very Large homes
  • Gaming features: Gaming port , Mobile game mode, PS5 compatible
  • ASUS features: AiMesh, AiProtection
RT-AX86 Series(RT-AX86U/RT-AX86S)
0.0 out of 5 stars.
  • RT-AX86 Series(RT-AX86U/RT-AX86S)
  • WiFi 6
  • AX5700, 2.4GHz AX: 3x3 + 5GHz AX: 4x4
  • Very Large homes
NEW
ASUS ZenWiFi BD5 Outdoor
0.0 out of 5 stars.
  • WiFi 7
  • BE5000, 2.4GHz AX: 2x2 + 5GHz AX: 2x2
  • Large homes
  • ASUS features: Smart Home Master, AiProtection Pro
ASUS ZenWiFi BD5
ASUS ZenWiFi BD5
ASUS ZenWiFi BD5
0.0 out of 5 stars.
  • WiFi 7
  • BE5000, 2.4GHz BE: 2x2 + 5GHz BE : 2x2
  • Large home, multi-floor home
  • ASUS features: AiMesh, Parental control, AiProtection
ASUS ZenWiFi BD4 Outdoor
0.0 out of 5 stars.
  • WiFi 7
  • BE3600, 2.4GHz AX: 2x2 + 5GHz AX: 2x2
  • Large homes
ASUS ZenWiFi BD4
ASUS ZenWiFi BD4
ASUS ZenWiFi BD4
0.0 out of 5 stars.
  • WiFi 7
  • BE3600, 2.4GHz BE: 2x2 + 5GHz BE : 2x2
ASUS ZenWiFi ET9
ASUS ZenWiFi ET9
ASUS ZenWiFi ET9
0.0 out of 5 stars.
  • WiFi 6E
  • AXE7800, 2.4GHz 2x2 + 5GHz 2x2 + 6GHz 4x4
  • Very large home
  • Coverage up to 7,800 sq. ft.
ASUS ZenWiFi AX Hybrid (XC5)
0.0 out of 5 stars.
  • WiFi AX MoCA Hybrid
  • AX3000 + MoCA 2.5
  • Very large home, multi-floor home
  • AiMesh, Parental control, AiProtection
previous image
next image
Related products
previous image
next image
comparison icon
(0)
